rdeis
- 135
- 58
- Feb 28, 2013
Falcon,
Colorado
Evening, all. I've got a head scratcher.
My clutch suddenly felt softer while driving, and I couldn't get the car in gear. Left me stranded me at a stop light, pointed up hill. Ugh.. Anyhow, rescued and safe, I discovered no fluid in the master cylinder reservoir and some fluid around the master cylinder shaft so assumed a bad clutch master. Got a new one under warranty from the FLAPS, swapped it. DUring the swap, I discovered that the adjustment extension someone welded for me had let go, so the problem was actually linkage not hydraulic. But there were signs of leakage and the new one was a warranty replacement, so I fixed the linkage properly and finished the swap.
I'm kinda wishing I hadn't-- I absolutely can't get it to bleed. I use a pressure bleeder, and the last two times I've done this it was easy. This time no success.
Here's the story: I add fluid, pressure, open the screw until the drain hose has no bubbles, press the pedal a few times, press the fork lever a few times, tighten everything up. Start the car and it shifts, huzzah! Turn the car off, clean everything up, start the car again and it won't go into gear.
I repeated this twice.
Went home to the back-up car, pulled the working master and slave from that and installed them on the broken car. They won't bleed either. I barely got it to go in gear once. I even tried hooking up the pressure bleeder backwards to force fluid and air up to the master from the slave and I still got nuthin'. Depending on details, it gets stiffer or softer, with more or less clutch fork movement, but no matter what I do I there isn't enough to engage the clutch.
- Don't think it's a bent/broken fork. The fork doesn't move nearly enough. Sometimes not at all.
- I don't think it's the cylinders- I've tried two sets with the same result, and one set was working fine on a different car.
- I'd suspect a leak or failure in the lines, but I can't find any fluid where it doesn't belong. No new puddles under the car.
- If it's trapped air, then trapped where? Why isn't the pressure bleed pushing it out like it has on previous jobs?
What happened?
What happened?
