clutch and shift linkages??
jw_55_55
108
Oct 3, 2005
Silver Lake, Wisconsin
I just bougt A 91 GS-T and the guy said it had a new clutch put in 15,000 miles ago, but the friction point is is almost at the floor when i push the clutch in??? any ideas?? Also sometimes when going to put it into first it doesnt want to go in or shoots out after i think i put it in gear. Is there anyway to adjust the shift linkages because there are no grinds otherwise in the transmission? thanks :confused:
check out vfaq.com It'll show you how to adjust your clutch.
You need to adjust it where its not so close to the floor. Thats why sometimes it won't go into first.
thanks for the reply, but i cant find where it shows you how to do this on that site??? if yuo could just point in the right direction on there. thanks
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
