johnovision27
- 401
- 2
- Apr 3, 2008
Ayr,
ON, Canada
Looking for a wiring diagram/pinout from the instrument cluster wiring harness.
Got a dash, for my other eclipse (currently dashless) and all the wires were cut. Got most of them together, but there are 3+ blue wires which all look the same.]
In the images below (showing the instrument cluster connection closest to the driver door), there are 3 blue wires which I can't determine where they connect to....
The wires with the red connectors on them and circled in green merge into the same wire further down the harness.
In the second connector, it shows the black harness connector which plugs in under the dash close to the driver door. It also has 2 blue connections on it, one of which is the merged wire as mentioned above. If someone could tell me where that merged wire connects to on that connector, it'll solve all my problems.
Cheers
Side note, I've checked a pinout for the instrument cluster, and the top blue wire is listed as A/T temp light, where the other 2 are listed as "?"
Cheers
