clip update
gixrman
1,997
17
Nov 13, 2002
Frederick, Maryland
So here's an update I FG'd in the lip that I cut off of the other clip. I made it so I could pull it off at any time. I had some fun with expandable foam this stuff is great for filling gaps.
I made the decision to keep the side vents but modified then to fit under the side markers. I will make the drivers side one functional as to that's were my oil cooler is. I then decided to do something different. I'm going to paint the main clip part flat black, the OE clip will remain gloss black and the duct inlets will be carbon fiber overlays along with the side vents. I think if I do the whole thing in CF it will be to much CF so I'll paint it first and then if I don't like it I can always CF it.
Removable is pretty sweet, seeing that there's snow on the ground!
As long as its black it won't look too ricey at all imo, looks pretty damn good if you ask me.
Using just regular home insulation sprayfoam or high density stuff? the high density would be stiffer and probably have more grip on the whole part.
Looks pretty decent, if your still able to help me out with my front bumper send me a pm please. Only problem(if that) that I kinda see is you reducing the amount that the fmic is exposed. But I also see you having the air air shoved in the middle of it instead of it all being exposed........Can you catch what I'm saying?
