Cheapest Way To Replace Bolts? Help!
4G63dsmpwr
307
Sep 13, 2002
Easton, Massachusetts
Well guys I picked up a really nice condition 14B turbo pretty cheap, along with a brand new manifold. I ported both of them and was looking forward to the install.
I wanted to do a extremely clean install, and wanted to get all new hardware. I was thinking maybe $50 or so...
I went to the dealer and got an invoice for the following things:
Manifold (studs, washers, nuts)
Turbo (bolts, washers)
O2 (bolts, nut, washers)
One oil return line gasket
One oil cap gasket
The total was $160.69!!!
I couldn't believe this! Where have you guys got your stuff? Should I just ditch the idea of a "clean install"? I'm not paying Mitsu $160.69 for some nuts and bolts! The turbo bolts were $10.69 A PIECE!
Thanks for any help, this is ridiculous.
I have heard of guys pulling those Heat-Treated Bolts out of the Aftermarket for less...
md005317 Exh Manifold Stud about $2 a piece fm Mitsu
md041192 Exh manifold Washer about 1.75 a piece fm Mitsu
md092806 Exh manifold Nut about $1.00 a piece fm Mitsu
BTW - you need a BUNCHA gaskets not on your list...
RRE has them for really cheap.. You should go there and check. I bought a Turbo bolt from them for $8 but I'm pretty sure they'll give you a discount or something if you purchased a little bit more. The second time I ordered from them, they gave me a 20% discount. :thumb:
