Cheap camber solutions?
420aPJ
80
Jul 27, 2010
Laveen, Arizona
Found a lot of things for 1gs but are there any cheap camber solutions for 2gs. Anything is is better than spending almost 400 dollars on a front and rear camber kit
There is no reason to spend money on a rear camber adjustment kit for a 2g. Actually, I think people that spend money on rear camber kits on 2g's are foolish. Use a couple washers and longer bolts between the rear upper control arm and the body. Bring extra washers to the alignment shop, and let them know you intend on having them adjust it.
For the front, there are a few options. For a mild drop, this isn't usually required at all, only adding a little negative camber, which is OK. Having an alignment done is still advised, as the toe will be out of whack. For deeper drops, or if you insist on having adjustable front camber, there are adjustable balljoints, eccentric bolts for the a-arm, and full-on replacement control arms to choose form.
