Proper Camber Kit.
I used the cheap ebay shim pieces for the rear and never installed the front ones. The good year shop was able to align all 4 wheels perfectly. I am lowered 1.5 inches on my GS. Hope that helps.
My car is ~1.5" lower with tokico springs - I used washers in the rear (about 1/8"-3/16" worth) which brought the rear camber to perfect; I didn't even have to adjust the rear toe after the camber was proper. On the front, I just left the camber the way it sat, which was a bit more negative than before I lowered it. I did have to correct toe on the front.
I destroyed an entire set of tires by driving around for only one week before I had my alignment fixed.
