changing 93 gsx to manual from auto
95 tsi awd
131
Oct 14, 2005
belleville, New Jersey
how much would it probaly cost to make a auto 93 gsx to manual?
Search? There's stuff ALLL over the a/t section of the site on this.
Parts can vary in price, from a new shep/tre trans, to a used 5spd. Used parts from a parts car, or brand new oem everything. It all depends on how much YOU can get everything for. I'd suggest trying to find someone who wants to swap manual to a/t.
How much it would cost is up to you, probably the cheapest way would be to find a donor car and swap everything over.
no i dont have a donor car. i would buy a manual trans and swap it in
ok your looking at anywhere between 2200 and 3500 for a new tranny. Plus the shifter cables at 80-120. Clutch is about 600 for a good one (including flywheel). so it will set you back about 4k for new equipment. I have a sugesstion though. Is this a race car or daily drivin? if it is a race car go look at IPT and stay auto. There are people in the 9s on their automatics. Not trying to rain on your parade but without a donor car good luck.
When I done a search a while back, it was actually cheaper to find a running 5 speed DSM then it was to buy all the parts. Just a short list for ya.
5speed tranny -average 400.00
5 speed flywheel-100-400
5 speed clutch- 100-1200
new slave under- 100
5 speed T-case - 50-75
4 bolt 5 speed rear end (yes they are different from 5sp to auto) -400.00
Shifter cables -25-75
Shifter base 25-75
Clutch petal 25-75
There is probably more. but that is what I can think off off the top of my head. I know when I check into it when I first got into DSM's, it was gonna be somewhere around 2200 bucks for everything, I got my '92 Laser for 2500.00 plus it had a few mods already. So I just sold my Auto.
I cant rember if the front axles are a different part numer tho so that may add to the cost. Plus all the work and a few other mis things. I also dont rember if the motor mounts are different. Its the little stuff that will kill you. It would be cheaper/easier to buy a non running 5 speed AWD that somebody has let the timing belt break and swap your motor into that car IMO.
