Changed flywheel and wheels not spinning freely in neutral
LV-DSM
Supporting VIP
118
Oct 6, 2002
Las Vegas, Nevada
Like the title says, changed my flywheel back to stock from a Fidanza. I went for a spin around the block and everything seemed fine, but out of curiosity, lifted the car up to make sure that my front wheels weren't spinning in neutral. No problem, but I found a slight resistance on the passenger side and it's difficult to spin the driver side.
When I had originally installed the Fidanza, I shimmed the pivot and changed the fork and TOB. I intended to remove the shim when reinstalling the OEM flywheel, but forgot. Could that be my problem or am I missing something. I hear no grinding and the clutch feels perfect with no engagement or disengagement issues. Any suggestions?
I'm presuming you meant to say "...lifted the car up to make sure that my front wheels were spinning in neutral." Perhaps this is a throw away response, but it couldn't be a dragging brake issue could it?
I think I poorly phrased the question. Wheels don't spin in neutral which is good, but when I try to manually spin the wheels it feels like the brakes are hanging up. Never was an issue before so I questioned my flywheel install. Ill check the brakes in the AM and report back. Thank you for the replies.
Ahhh! I was thinking in terms of spinning them manually, not them spinning with the engine running in neutral -- got it :)! Still, if they aren't turning with the engine running in neutral, it seems more likely a brake drag issue than the clutch. I find that brake drag tends to creep up on me gradually and one of the symptoms is a higher rim temp than normal at the problem wheel (also, gas mileage gradually drops and so does throttle response).
