CertiFit front bumper cover questions
Warharan
121
Dec 2, 2006
Los Angeles, California
I searched and no luck to my questions. As the title suggests...
1. CertiFit has a front bumper cover for 95-96 Eclipses. Will this fit perfectly on the 95-96 Talon without changing the headlights or will I have to change the headlights too?
2. Does the CertiFit front bumper cover have the molded Mitsubishi diamond logo embrossed on the front or is it plain and smooth?
3. How's the quality? Holds up well or thin and flimsey?
Thanks.
Thanks.
1. If they make a cover for both the Eclipse 2Ga and the 2Gb there is no reason to expect the headlights not to be appropriate for the model year. All 2G Talons use the 2Ga sized headlamps so you should not need a change.
2. I have bought them both ways in the 2Gb bumper STYLE but it was up to what they happened to have when I got there (we have a local branch in Phoenix).
3. I'm happy with my bumpers, not too flimsy and a good fit for aftermarket. You can't beat the price either. I get them for around $50 with tax if I go pick them up.
Im pretty sure the talons front emblem sets into a triangle spot on the front bumper. I would go out and look to be sure but its freezing and you probably already know. I wouldn't count on the one from certifit to have it. And your talon lights will fit.
My 97-99 Eclipse Front Bumper was from CertiFit. Worked out fine. And also one headlight was from them too. And it was the same was the other one I got off Ebay. Depo Headlight Assy.
My old 96' TSi AWD it went on.
I work in a body shop and we deal with Certi Fit or Sorta Fit, on a regular basis. Its an aftermarket part so you get aftermarket fit. It'll fit good but the lines wont be perfect like an oem bumper. Your gaps will probably be a little off but its different from bumper to bumper. You may get one that fits perfect.
