CEL read
brute
1,551
47
Jun 29, 2005
Rio Rancho, New Mexico
I just used vfaq to read my Galant's CEL. It did L-L-S... 21... Engine coolant temperature sensor. My car is running fine, warms up to about half-gauge, and stays there. What's this engine coolant temperature sensor? Where is it located?
Sorry I don't have a logger to log coolant temperatures for you, but DSM Link should be in around Christmas. :sneaky:
BTW: I was thinking about my car running normally, and the only thing bad I can think of is the cold starts. It takes a couple (3-5) tries to get it to start up and idle normally. Would my coolant temperature sensor going bad possibly make the ECU think it's warm all the time, so it runs warm timing? But since the engine is actually cold, the timing would make it hard to start? Once it's warmed up, it starts and idles like a champ.
Means the car is running in open loop mode versus closed loop mode. Timing and fuel are effected by this. Sounds like a wiring issue
Derek,
The engine coolant temperature sensor is what the ECU uses to determine coolant temperature. The device that controls the meter in your dash is the coolant temperature sending unit, a separate component.
The coolant temperature sensor is the larger of the two sensors in the thermostat housing, and is the one facing the firewall. To remove it, you'll have to drain the coolant slightly. There's a check for it in the Haynes manual (section 6-9 in mine) to confirm it is the sensor that's faulty and not a wiring problem.
Hope that helps.
I dont' know if you've had yours unplugged anytime lately, but I ran into the same code after my engine swap. All I did to fix it was unplug the sensor and was the connection out with electronics cleaner. Then it worked fine when I plugged it back up. Good luck.
I found out the problem. There's two connectors. Left (2 wires) and right (1 wire). Apparently the right (1 wire) is the temperature sending unit, and the left (2 wires) is the actual temperature sensor. With that said, I look down there and find that both wires going to the left connector are just sitting there, out of their connector. I did my best at the junkyard, but ended up buying the wrong couple things. So now I have crimped two spades on, and attached them to what I presumed was the right ones. Then I drove back to college for the week. My CEL was still there so I either have a different problem or I should switch the spades.
