CEL doesnt go off
Black420RS
166
Jan 29, 2009
Tegucigalpa, HN, Central America
hi,
i am having problems with my cel after a huge accident before that everything was ok
the scanner says P0443 Evap valve 1
we changed the selenoid under the passenger side front bumper and checked the hoses and still the same problem
any ideas guys?
your help will be very apreciated:pray:
regards
MAPP
I'm assuming you reset the ECU after this?
I'd check all the hoses going to the canister as well. And care to explain on the huge accident? That may help find the problem
hi, i found something else, my cat o2 sensor is broken, can it be the reason of that code? what do you think?
is weird because the scanner doesnt say anything about the 02 sensor
regards
MAPP
best way to test an EVAP system is to seal the system and fill it with smoke from a smoke machine, a local smog tech should be able to test the system for you and look for leaks. EVAP problems could be anything. . overfilling the car with gas causes the liquid gas into the charcoal canister and that will ruin it and the senors and vales inside. . road grime gets sucked up inside check valves, leaks in hoses. .
