DrBrown
- 44
- 0
- May 27, 2003
the Kron,
Okay boostheads I need some experienced advice. I currently have a 2.5" turbo back w/ test pipe exhaust making around 300whp 310trq. I do intend on trying to make as much as 340whp and my ### state requires emission testing. Theres a nice $500 fine for driving w/out a catalytic converter so I want to build a real street legal exhaust. My plan is to go with a 3" high flow cat like a magnaflow or catco and build a 3" mandrel catback to free up the backpressure from adding the cat. Have you guys had any good/bad experience using high flow converters with turbos? Ive heard from some folks that the rich conditions can burn out the ceramic core. I dont want to waste $100 on a cat but I do need to get a legal exhaust so I can pass emissions. I dont want to loose too much power from the cat so I thought the larger dia catback would at least reduce the power loss. Im also curious what it will do to the lag issue even if its a large 3" cat. If anyone can share some expertise on the subject I would appreciate input. Thanks in advance!
