CAS turns off car!
killerdakarm3
Jun 18, 2010
Reedley, California
Basically I have a no start issue which I know has to do with wiring. I tried another thread which was not answered successfully. So I decided to test my CAS and see if I had spark. Had the car on the ON position with the spark plug out on the valve cover. Didnt take off the CAS but I was still able to turn it. When I turned it so far in one direction, no spark but then I would hear my turbo timer counting down. The car would stay off untill I turned the CAS back the other way and the car would come on as if I turned the ignition to ON yet it was on all along. Any ideas? Maybe a short or something?
Heres a link to my other thread for some other info. http://www.dsmtuners.com/forums/newbie-forum/373542-no-power-mpi-relay.html
I really appreciate any help. Thanks!
Chris
Not sure what you're trying to accomplish with the CAS. The CAS is the camshaft angle sensor, it's adjustment is used for setting base timing.
If you were doing this "test" with key on engine off(and the ignition shut off): you definitely have a wiring issue.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
