CAS Timing?
way2slowtalon
147
Oct 24, 2004
Newington, Connecticut
How can you check Cam Angle Sensor Timing on a 1g? (I did try searching) My timing is way off, but i know the belt timing is perfect. Thanks
What do you mean by belt timing is perfect? Timing belt?
If you say that mechanical timing is perfect, then you need to check your ignition timing. Hook up a timing light and point it at your crank pulley. You want the mark on your crank pulley to be hovering around 5* on the timing belt cover.
