CAS timing with dsmlink
Don't forget to ground the timing adjustment pin on the firewall, and disconnect any datalogger (or DSMLink) cable while setting the timing.
You'll need a timing gun. They're cheap... $20 tops, for a basic one, which is all you need.
And yeah, set it to five degrees BTDC.
