Car Wont Start??
sLiCRiC911
Mar 17, 2005
Yonkers, New York
well just finally got my 6 bolt swap down and good to go start the car drive it home everything is ok. go home register the car put plates on it and the car get a damn allergic reaction i swear LOL.
went to go start the 2g and when i turn the key the car went dead like the battery just went out. check the battery and its got juice but for some reason isn't getting any connection. now i would place the jumper cables on the negeative terminal of the battery and boom all of a sudden the car will get power if i take it off it dies. so i leave the jumper cable on the terminal and go to start the car. the car cranks but seems to not want to start. WTF tryin to have some fun while the snow is on the ground anyone can help me ??? any suggestions??
_-~RiC~-_
check your ignition fuse. its in the fuse box by your battery. i think its a 30amp fuse. had it happen to me a couple of times. why, i dont know but thats where i would look. wait, just reread your post. sounds like a problem with maybe your crank position sensor. check to see if you have spark and fuel when trying to start the car. if you have neither, its related to that or your cas. i believe. good luck.
old post but it was the stupid starter wire that wasnt connected. there was a plug just hanging from the side that i noticed didnt have anything pluging into it. found the part of the harness and bam it started.. then it took foreer since i kept flooding the engine:D, then it took forever to start beacuse i didnt know i need to change the 6 bolt thermstat with a 2g one to read:D...... DSM what a learning experince
