car wont start
blackifre22
172
Feb 16, 2003
powell, Ohio
i put an eprom ecu in my car and went to crank it over.....nothing. everything works all my lights on come like normal. my afc doent come on or anyting. my check engine light doesnt come on. i put the stock ecu in and it does the same thing. so its not the ecu. it wont crank or nothin. i havent blown any fueses tha i can tell unde the hood all those lool fine i lost my cover for my underdash fuses are they any there that i should check for?
any ideas...
ps battery is fully charged
dude my car is doing the identical thing, i just swapped ECU's too...i just made a post on it too
battery terminals are cleaned and tight and yes it worked fine before i swapped ecus....swapping back to the orginal ecu has done nothing...same results
If the ECU is not coming on then check the fuse under the hood its one of those big weird square ones. I had mine blowing those when I had the fan grounded our wrong everything works BUT the afc didn't come on and the ecu would not click. If the AFC doesn't come on the ECU has no power check that fuse.
ummm my car isn't here to chech for you its a blue fuse I believe its one of the ones with the clear top on it in the row closest to the fire wall. I will try and remember to take a pic for you tonight.
Its one of the ones in the oval but I'm pretty sure its the circled one I foud that pic on the net not of my car.
eclipsegxsdrive said:
do u have fuel pressure, is the fuel pump working? check that
Fuel has nothing to do with it if his AFC isn't working his ECU isn't working if his ECU isn't working his car isn't starting.
I tested it today and the ecu and afc are definalty not getting any power. we checked all the fuses that we could find they are fine. Also, the front wipers and the rear defroster are not working either. (fuses are fine though)
20 bucks paypal'ed to the person that can get my car running
found the problem...we removed the radio and found a loose connector we plugged it in and magically we had ecu power, rear defroster and wipers...
thanks everyone for your help
Pay U R self 20 bucks! You know I should have suggested that I had the same prob tail lights after my 6bolt swap something was funky behind the radio.
