tstkl
- 3,890
- 78
- Feb 10, 2005
SoCal,
California
ok so i took out my intake pipe, stock mas, air filter, licp, intercooler, uicp, intake manifold, put on a new one, new throttle body elbow, a gm 3 inch mas, and a maft, but nothing else so far, i need to remove the ac so the intercooler will fit... i actually have everything on the car right now except the second half of the intercooler pipe (both lower and upper) and the intercooler.. doesnt matter cuz its in blow through set up, right? wrong.. go to start the car and it wont catch, just turns over. i held it for a little bit cuz i thought it might just be from the car not running since 8-25-05.... didnt work... so i stop and try again... THUNK.. sounds like something fell out of my car... then the same thing.. one last time... same thing... got out of my car... looked around as hard as i could for anything possible... only thing i can think of.. the line for my coolant which goes downward and attaches to nothing was pinched shut.. maybe my ignition is in the wrong order.. dunno how i have it right now, but i went by what someone posted here.. any help is greatly appreciated.. im scared to death right now.. i dont want to have to take it somewhere....
only for testing.... i think i have vacume leaks though... not a bad maf... because when i gave it gas to keep it running the maf would go up to 500 hz... and when i took my foot off it would go way down... to me signifying that the engine was getting its air fix from somewhere else for the amount of fuel it was getting, so it gave it less fuel since no air was passing the maf... but maybe the maf is broken... let me go have another gatorade and well find out...
, the upper seal that goes into the fuel rail is call the injector o-ring, dielectric grease should be used during installation. The lower seal that goes into the head is call injector insulator, some uses RTV during install but not necessary unless it still leaks after install like in my case.
