Car won't start....fuse possibly? Help.
FutureGSXOwner
274
Aug 27, 2002
Philly Burbs, Pennsylvania
I just searched for the answer to my issue but I can't find anything. I just recently installed a Duralast battery about a month ago. The car was starting just fine. The car sat for about three days and I went to start it last night, turned the key to start it, electric powered up for like two seconds and then boom, everything went off. The car doesn't crank at all. No electric, no nothing. I'm guessing it's a fuse. Does anyone know which fuse could've went bad here? I'm hoping this isn't a bad alternator. My roomate (former dsm owner) told me it's probably the "battery fuse". Does this sound accurate?
Have you checked your connection at the battery terminals?
It's not uncommon for our cars to develop a bad connection for absolutely no reason. Works fine for months, then with no logical reason, you go to start the car one day, dash lights up, turn the key to engage the starter and click.... everything is dead. Same thing you just described.
Smart guy. The moron that installed my battery didn't tighten the positive terminal properly. Resolved. Thanks for the help and swift replies.
I have a 95 Gs-t the same thing happened to me, when i turn the key, nothing happens ,
i already checked the + and the - on the battery so im hoping it's just a fuse ..
wich fuse should i check ?
Go through them all, take them all out and make sure the right fuse is in there. The kid who owned my old car before me messed all the wiring up so I had to rewire my entire car because of it, and my new car was missing a fuse.
  • Wanted 6 bolt NT water pipe
    • chrisman287
