Car wont go into any gears still when car running!
Talon00b
138
Jul 30, 2005
London,
now i was reading on this and i read somewhere if the clutch is new that they push started it and it "freed" the clutch and it worked could this be it? i already bled the fluid and my clutch pedal still feels loose like crazy i donno maybe thats how its saposto feel on these cars but every other car iv driving is way harder then this any suggestions
Brad :(
You definitely have to the pull the trans if the clutch fork is resting towards the passenger side without the clutch depressed. To save your self the anguish of doing it again, make sure you get the following when you order parts:
OEM clutch fork
OEM pivot ball
OEM TOB and clip
Lube the shaft that the TOB slides on with moly, make sure your flywheel step is between .608-.613" and that your PP/disc are aligned correctly.
