2G Car wont crank period
"16 power"
Mar 27, 2011
las vegas, Nevada
Alright guys I have a 95 Eclipse gst with a 16 Turbo that For some reson I can't get to even crank any one have any idea??? Here is what I have done bran new starter via autozone battery also new no crank period any idea please help!!
Did you even read the article?
Yes... a battery is either good or dead, no matter what year. A starter either works or it doesn't, no matter what year. Step #5 under part I even tells you the amperage rating of the alternator fuse for both 1G's and 2G's.
You may also want to try searching. Searching titles for "won't start" turns up 500 threads.
Not familiar with 2Gs, but do they have the same plug in wire on the starter as 1gs? I remember my wire got pulled off somehow, car wouldn't crank.
The signal wire for the starter is Black with a Yellow stripe. It has a connector under the thermostat housing area. Its a 2pin connector with a single wire going into and coming out of the connector.
Test it for power. If it does have power, then the start is shot or the power cable coming from the starter to battery is bad.
