car will not run/rev right
talones94
Apr 1, 2009
connersville, Indiana
ok i have searched and searched and cant find what my car is doing exactly they are cloe but not right on and ive tryed what their answers were. Ok so i start my car it runs pretty good but when i go to rev it it will bog down and die unless i take my foot off the gas i have replaced every sensor on the car i put a new maf in new tps new everything on the intake new cam position sensor checked all the plugs and wires brand new plug wires new coil pack new fuel filter and pump checked all of my injectors and still nothing i have no cel light it was on then i put a new maf in because when i pulled the code it said the volume ir intake so 5took care of that it has a new alternator i have checked all vaccum lines that i can find and found no leaks my times looks to be on the only thing i can come to a conclsion about is that my o2 sensor may be bad i can completly unplug my o2 and nothing will change i replaced the fpr and then i was thinking maybe the power transister but im not sure if that would cause my problem i have spark on each plug and if i pull, the wires off one by one it makes a huge difference so im lost here im about over this car and to never get another ithis is my first one and i bought it this way thinking maybe it isnt nothing big but bno matter hwat i do nothing changes i took out my ecu and no leaks actually looks brand new i have checked all of my relays and they all work the car will start for meno matter what usually it just wont rev, it just bogs down and wants to die and if i hold it to the floor it will drop down in rpms and hold at 500 rpms and try to catch up but it will die i can sometimes get it to rev but i have to play with the peddle a lot to get it that far there is no miss in while idling and there is no milky oil no bad coolant it stll looks brand new im just looking for ideas and any would be appreciated if you want a video then i can post one just let me know my car is a 1994 eagle talon 2.0 liter dohc non turbo so cross out boost leaks it has magnaflow exhaust on it and has been since i owned it and if any body lives near connersville IN feel free to get ahold of me if you want to see it or anything i want to get this car going to bad but im about to give up so please help me im new to posting on this site but since i found it i have learned quite afew things about these cars so just please helpo me thanks cody......pm me or anything i am on this site daily usually
well i had to solve thhis one myslef i guess but it was the fuel pump in the tank the line that comes off of it was loosing my presssure :hellyeah::rocks:
