car stumbles and won't accelerate
2Gtalon
Dec 3, 2002
Hallandale, Florida
ok...we're dealing with a 6 bolt swap with 550's, 255 fp, s-afc, custom front mount,and sb racing/pte 50-1. when you give the car any kind of throttle from idle it boogs and falls on it's ass around 1500 rpms and it doesn't want to go up in rpms. it sounds and feels like it's not getting enough air. i've checked what i think to be almost everything that could cause this problem, such as: changing the mas, change the injectors, coil pack, resistor, plugs, wires, making sure the turbo is spinning freely and not blown(brand new turbo), changing the manifold differential pressure sensor, changing the ecu. i have no clue what could be causing this problem. could anything but the ecu cause the injectors to get poor/ not enough power(voltage)? any help or advice is greatly aprreciated.
andre
thank you to all of you guys who looked at this thread and didn't say anything. don't worry i figured it out on my own. i'm especially happy to say that all the expertise on this site was put to good use to solve this problem and all the other problems that go unanswered.
p.s.- this is one of the reasons i'm selling my talon
  • Wanted 6 bolt NT water pipe
    • chrisman287
