Car Stalls when I hit Brakes Hard, Mushy Brakes
90TalonTsiPa
Sep 8, 2004
Pittsburgh, Pennsylvania
So lil quick background -1990 Eagle Talon Tsi AWD- Replaced Pass. Side Rear Caliper, Rotors, Pads, Replaced Alt., Replaced Batt. w/ Optima Red Top, IC Tested it as per VFAQ's, Installed MBC, Intake pipe w/ K&N, and Boost Gauge only mods.
First Problem - Keep in mind i've never been low or LOST any brake Fluid!!! Back Pass side caliper was bad so i replaced, ok no problem, Brakes were squishy and very hard to stop, so i Bled Brakes again and again, and again, still getting air in my brakes, I can bleed them with a 1 man bleeder and the brakes will feel PERFECT, but after a while or the car sits, brakes feel squishy again. So i bled them a last time and they ride ok but not great *(they stop), wasn't sure if this is a Master Cylinder Problem??- but then why aren't BOTH back brakes bad (i.e. Getting Air and not fluid) the Drivers side bleeds perfect, and soo does the Back Pass side sometimes but I bled it yestereday till no bubbles checked again today and more bubbles. The Master Cylinder only knows Front and Back right?, maybe a PROP. Valve problem?? But if the line was clogged i wouldnt' even get air right???
2nd problem or do these problems relate (Vacuum)?...
When i come to a stop, my car stalls, not all the time if I ease into the stop it's ok, if i am 30-40 mph and come to a red light quick, Car stalls, Second Test - I am driving at 30-40mph drop it into Neutral and Brake Car will die and stall out.
Vacuum Leak somewhere??? I pressurized system didn't SouND like any leaks..?any Suggestions anyone???
-Ray
I just bought this car about 3 months, ago soo no idea when or IF these were ever checked or changed... also just bought a Volt Meter yesterday soo if theres Tests Please let me know, OHMS Resistance Checking etc.
Vacuum is around 20....., 25 while driving for vacuum boost is around 13-14 psi,
Update did some research on the forums, came up with list of things to check, FIAV
TPS, ICS, BISS, Some Small white connector to the Left of my Cruise Control
- BISS is Messed up looks stripped and Turned ALL The way IN or Down, prob part of the problem
- FIAV, well the two coolant lines were off, but i connected them that seemed to help with the real Fast Idle and Idle Surge , of 1500 RPMS... side note also replaced the Coolant Temp sensor, Coolant ECM Sensor, that too helped w/ Idle Surge.
TPS/ICS is there a check i can do for these?? Ohms resistance check?
And I'll look for the small white connector -
Does anyone think this is Def. A Vaccum issue, because of the Brake Booster or
is this more of a Brake Issue / Master Cylinder causing air to get in the lines or
is this a Idle problem / TPS/BISS/ICS which doesn't explain the recurring air and mushy brakes...
anyone?? just wondering before i dump money in the wrong place
Sounds like a brake booster problem to me. Something inside the booster sounds like its leaking.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
