car just shut off!!! (NEED HELP NOW)
philipkrotch
Banned Member
904
Feb 9, 2004
butler, Pennsylvania
ok, im on break for lunch and im sittin in Mcdonalds parkin lot and my car just shuts off. wont start, and all i can smell is fuel. i flip out , push it into a spot and leave it. i go back 10 min later and check to see if i got spark , because the only thing i had changed was a coil pack. well i had spark comin out of it. i put the wires back on and it fired right up. any suggestions on what the prob is? im gunna change coil packs and see if it quits doing it, i just wanan see if anyomne had the same prob before. thanks guys.
hey,
ive been having the same problem, but i figured out what it is
look at your coil packs, go directly to the left of them, there is a plug about 4 inches long, pull it off and then push it back on tightly, it is the power transistor plug, it can vibrate loose. my car did the same exact thing anf i had the same exact symptoms as you did.
ron
ya, im gunna piss with it after school and see if i can figure anything else out. any other replies before then would be grteatly appreciated so i can try and trouble shoot any option possible. thanks!
