Car has bad Idle...
H.A.R.T 4G63DSM
84
Dec 19, 2003
Las Vegas, Nevada
Okay heres the story. My car had mad idleing problems, when I would drive and put the clutch in the idle would drop below 750rpms and almost die out. Okay so a bunch of people told me to change the ISC (Idle Speed Control). I did and it idle well but it goes up to 2000rpms when the cars gets warmed up. But when it does idle at 900rpms, it sounds like Im running on 3 cylinders. Pls help. :talon:
Is it surging or is going up the 2000 and when warm going back down to 900?
I had a bunch of idle probs a few months ago and it ended up being a bad intake manifold gasket, A bad biss screw o-ring gasket, and really fine adjusting the TPS switch.
if your running on 3 cylinders youll feel it, youll be very slugish. check your wires, and plugs. cause it sounds like you probably are running on 3 cylinders
Hi BOBS90TURBO, how did you adjusted the TPS switch please? What's are the fine data for this? I have my car in Mitsu servis, but they don't have a data for computer for adjusting my TPS. Thanks. :dsm:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
