WillRaceForBeer
- 143
- 3
- Feb 7, 2003
Fairfax,
Virginia
I'm new to manual dsm's, and today my 1990 GSX got stuck in 5th gear on the highway. I was coming down an exit ramp and simply couldn't shift out of the gear
Pulled over, killed the car, attempted to yank it out... no luck, and I yanked hard. It's in a limbo between 5th and neutral now. I can keep the shifter pulled back and there is no engagement, but with it pushed forward (towards 5th) it grinds... I can't move to any other gears, including Reverse, like i said I tried to yank it back.
I've spoke with several knowledgeable people and done some research but saw that no-one had got stuck in 5th before. Typically if it were 1,2,3,4 broken shiftforks are a good posibility, so should I assume the same for 5th? And are there other things I should check that could be locking it in this position?
As far as I could tell the tranny is in good shape with the only issue being a bad 1st syncro (used to grind going into 1st before some adjustment of the clutch)
I've got the car back home now, so let me know what you guys think I should do next..
Pulled over, killed the car, attempted to yank it out... no luck, and I yanked hard. It's in a limbo between 5th and neutral now. I can keep the shifter pulled back and there is no engagement, but with it pushed forward (towards 5th) it grinds... I can't move to any other gears, including Reverse, like i said I tried to yank it back.I've spoke with several knowledgeable people and done some research but saw that no-one had got stuck in 5th before. Typically if it were 1,2,3,4 broken shiftforks are a good posibility, so should I assume the same for 5th? And are there other things I should check that could be locking it in this position?
