Car Dies when brake is pressed and lights are goin haywire!!
2gboostin98
Nov 27, 2007
Greenfield, Wisconsin
Just got my first dsm 97 gst !!
Well I was driving and went to get a new flexpipe welded in and my carwouldnt start after.
So I jump started it and after driving all the lights go dim and car dies when I press the brake:( Also I noticed that my Greddy EBC is goin on and off . The radio works and dies and its just going nuts!!
So I stalled again when I came to a stop using the brakes. I jumped it and got home goin 10mph! When I gave it gas it boggs and stutters.
Any help I would appreciate it!! I got the car cheap but needed work. I also just put in new plugs and wires!!
Did you unplug the alternator/unhook the battery when you were welding? Were you arc welding? That might have ruined your alternator or battery.
Tim
I got the welding doneby a shop. Also now after the car only starting with jump starts. The car is making loud knocking sound like the rod hitting something???????
So I shut the car off and now any suggestions on what to do next? Im goin to check my ecu to see maybe it fried?
I would recommend to have a shop look at it as it could be a variety of things. To me it sounds to be a bad battery, terminals, alternator, or some positive wiring grounding out on the body somewhere.
