CAN'T LOG? Logger Problems!
kraka
821
4
Dec 31, 2003
Chicago/Iowa City, Illinois
Ok, so Im dying to tune my car, but this damn logger is the only thing setting me back at this point...Here's the problem:
Im running mmcd 1.5 on my PalmIIIXe....I have it connected to a cradle, and a diagnostic 3 prong connector hooked up....
When I go to log, usually, no data will even show up....Every once in a while the numbers will show up correctly, showing my rpm and timing, but a couple seconds later it will cut out for good....Most times, if the numbers appear on the screen, they are computer error numbers like 288 counts of knock randomly or 7999 rpm at idle....
When I go to "TEST" on the mmcd screen, and press the DTC button, it either says "ECU COMM ERROR" or "SERIAL COMM ERROR".....
I have just replaced the cable I had before with a higher quality logger cable known to work, and still, no data and the same 2 codes...
HELP PLEASE! Im not throwing my injectors in unless I know what my car is doing!
Thanks a bunch
-Josh
Input please!! My ABS light stays on all the time instead of just when the cable is in...Any input is welcome, unless it's not serious
If the cable is a known working cable and the palm is good then you must have it hooked up incorrectly or your connections arent good enough.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
