cant get master cylinder out
highlandgst
805
May 11, 2009
miller, Indiana
SO I have it unbolted from the firewall... and the cottin pin is out .. but i cant get the line bolt out of the tope i have no room to get a wrench in there to get to it and i did at one point but it was so damn tight and no area to move the wrench ... so i couldnt move the bolt and suggestions ?
by the way its the clutch master
thats what I figured but i didnt want to run a whole new line but bleh i was hoping to cut an add a fitting but i suppose an ss clutch line would be good anyone got a good priced one ? LOL
als im looking at the ss braided lines whoudlt i need brackets or would it flail around ? LOL
so you are saying you cant get the fluid line fitting from the master cylinder?.....are you using a flared 10mm wrench?
and the SS lines go for cheap, even a barely used one will only cost you just a couple of bucks
yeah im using a flared line wrench what im saying is i cant get it into the area to actualy move it theres no room
