cant figure out what happen
Yellow94
44
Feb 21, 2008
Rio Rancho, New Mexico
I did the timing belt and BS delete. The car was runnihg fine for 300 miles. Today I was driving up this hill and the car dies at a light. I tried to restart it but it would not start. I towed the car home and thought it might be the timing belt. I pulled the top timing cover and the belt looked good, i then pulled the balancer to look at the crank pully and the belt looked good there. I rotated the engine by hand and the timing belt has all the teeth and is not loose on the cam or crank pulleys. I tried to align all the timing marks but I cant. I have a screw driver in the spark plug hole and can not get the number 1 cylinder at TDC with the cam gears and crank gears aligned. I have no idea what the hell is going on. I pulled the valve cover and all the rockers move with the cams and all the rockers are tight against the valve springs. Any thought what is going on. 91 talon tsi 6 bolt.
later
Orlie
Before i pulled the timing belt i made sure the pistons were in the middle of the cylinders. I pulled the timing belt an moved the cam gear dowels to 12 aclock. I inspected the head again for loose rocker arms or broke springs and it all looks good. Im gonna continue tomorrow and hopefully the compression test will show good compression on all cylinders. Has anyone here ever not bent valves.
later
Orlie
Did you do the Timing belt yourself originally? Did you use zipties and wrenches to hold the gears in the right place? If you know you did it right the first time, keep turning the crank until the gears go around at least 6 times, everything will only line up once every 6 rotations of the gears.
Yes I did the timing belt myself. I also tried to align the timing marks, I must have rotated the crank 50 times trying to align the timing marks. Will see what happens tonight when I install a new timimg belt.
later
Orlie
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
