Can you visually tell the difference between N/A and turbo pressure plates?
Daveed
231
Feb 25, 2005
Olympia, Washington
From my searches I gathered the following:
1) the clutch disc is the same on all of the 4g63s
2) the turbo flywheel is different from the N/A (2 step vs flat) and there may be some possible differences in the AWD to FD in regards to the position of the starter ring placement
Now, I think the turbo vs N/A pressure plates are different. Can you visually tell them apart?
Got any measurements or other visual cues?
Background: I've got a clutch I'm about to put in my car and want to make sure it really is a turbo pressure plate. It looks brand new and the guy I got it from said it was a turbo clutch with about 1000miles on it (virtually zero wear on it).
Turbo pressure plates are much thicker thus the reason the flywheel is steped.
Good to hear. Thanks.:thumb:
The two I've got (the worn out one and the "new" one) both look virtually identical. I just wanted to make sure there wasn't a hidden type of difference like spring rates or something you can't see.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
