Can you buy new bearings for a evo3 16g?
90 GSX
322
Jun 24, 2004
Fremont, California
I have only seen bearings for a big16g but the the thrust bearing is thinner and the shaft bearings aren't tall enough.
Also, can you fit a turbine/exhaust housing from a big16g on to an evo3 center section???
You can buy the bearings but may as well get the whole rebuild kit. You can get them for under 100 off ebay or FP sells them as well. the EVO and the B16g is the same bearings etc.
Also you can use the B16g turbine housing as long as its a 7cm housing. It will be stamped 7 in many areas
check turbochargers.com they deal in most everything. If not a rebuilt kit is probably in order, just because it has everything.
14b, s16g, b16g, evo3 16g and 20g all use the exact same rebuild kit to the best of my knowledge. I've seen an evo3, s16g, and a 14b all apart and they are all identical on the inside. The only difference is the compressor wheel and cover, and hotside (6 or 7cm) other then that, they're all the same :thumb:
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
