Can we name this goop, grease, sludge???????
is this a hard job, i assisted once on my old talon, but is this something that can be done in a home garage??
Is it going to be a PITA? Yes.
Check out the vfaq here: VFAQ CVboot Replacement
Actually I just realized that none of the pics are showing up anymore on the actual site. You can read the article with some pics (better than none) here: Way Back Web Archive
Pretty easy to replace the axle if you do it right. Pop the hub bolt. Take off lower control arm (both hub-side and frame-side), get out your pickle fork and pop the tie rod end off. Get in there, take your pickle fork or screwdriver, give it some good blunt hits to the pickle fork to pop the axle out. Done!
