Can we dsmers use this turbo?
Any way to avoid that limit reached so quickly
Yes we can... Holset vgt.
I wonder whee it stands on the turbo line. Better than fpgreen or hx35?
we have one of these sitting in the part room at my college. its mint. and FREEKING HUGE... its almost as big as the head, and definitely weighs more.
you could use it, but dont expect to drive it on the street, ever. idk if it would ever even spool that thing. now if you had a BBC in your dsm...
after learning the name I searched youtube for any dsm with it. Running decent with it too.
There are also a few write ups on it. Claiming to provide 57lbs/min at 28 psi. It was called "impressive"...
If we do this then we drive a turbo with a dsm attached to it.
I'm going to have to agree with everyone else. This thing would suck on a DSM for multiple reasons, and even if you had enough displacement for it it would still be crappy.
Those were done with the HE351; a turbo that is not much different from a HX35.
If this happens to be a HE551, it's basically a Variable Geometry Turbine HX55 intended for 12.0+ Liter diesels. Huge.
