Can someone tell me where this plug goes?Pics inside.
95EclipseGST
406
Mar 1, 2002
Kansas City, Missouri
Im almost done with this 6bolt swap and cant find where this plug goes anywhere.There is only 1 more thats like it and thats the MDP sensor that goes on top of the intake and THAT one is plugged in.It is a 3 pin plug and has a yellow wire ,black and white, and a black wire coming from it.Also its the only other plug that you clip it on with that u shaped wire.kinda like a paperclip.Anyway i have looked everywhere and cant find where this goes.Can someone look at their car and tell me what it goes to? Its just like the clip/harness that goes to the MDP sensor.Thanks for any help i have looked for 45 minutes to where it goes.
Throttle position sensor looks like it, but is a 4 prong.This one is 3 prong. TPS and MDP are hooked up. Any one else might know where this goes? Im trying to get the car running today so any help is very much appreciated.
I think i had something hooked up wrong because in all the pics i looked at the plug that goes to the MDP sensor on top of the intake is a brown 3 pin plug like the one in the pic. Well i had a 3 pin plug that has green/green-lightgreen/black hooked up to the MDP sensor.If that is true that that brown plug "3pin" goes to MDP then i dont know where this other 3pin greenwhite wire one goes.It is by the Fuel injector wires so its really short with not any places to plug it in where it will reach. Theres not too many 3 pin plugs but i cant find another place for a 3pin to even hook up to.Everything is plugged up except this.I will look by the rear engine mount etc like you said.Thanks
The brown 3pin one i put going to the speedometer."thats the one i couldnt find" Thanks PIRATE44 and thats a brown plug.BUT now the one going to the MDP sensor is the green wired one and from engine pics i was looking through shows them having a brown plug.The one i have going to the MDP seems like the only one that will work and now i have all sensors hooked up.Just that the plug isnt brown like about 10 other pics i saw and the green wired one really cant reach anywhere else.Can anyone tell me if it sounds like its still good to go?Also in the bottom left of this pic is the power trans thing that came off the 2g coil pack.Was it safe to remove the metal bracket that it was on and just tuck it away anywhere.Its the one with that big plug on it.The other wires are the CAS wiring job that i need to solder and finish.
