can someone recommend a FMIC kit?
JiveMasterT
1,848
9
Jan 3, 2004
Chest of Westerson, New York
I'm looking for a FMIC that I can bolt up to my car right now with short route piping and then also have the flexibility to move to an FP Green when I get it. I want the IC now though cause my factory pipes have a little leak in them. Oh, and I also would need the pipes flanged for a hks ssqv. any ideas? thanks!
http://www.dejontool.com/DSM-2g FIC.htm
They have a racing front mount for $599, you have to purchase the piping seperately. Check out the site it tells you all about it. And you can have the pipes flanged for the ssqv.
yeah, i had seen that, and i was even going to order it but i dont like how i gotta cut my t25 in order to make it work. could i just get a C shaped pipe made to make it work or would that be bad for flow?
Any FMIC that I have seen with the short route pipeing will basically take the same routing as the dejon tool one that you have looked at. So it looks like if you want the short route your gonna have to modify it abit to work with the t25. Slowboy racing makes a nice FMIC/short route kit & its huge. Victory performance also makes a few nice kits but are abit more expensive over the SBR, but in my opinion have nicer endtanks (designed for better flow). Another place is Kinetic Motorsports.
what if i had an exhaust shop make me a C shaped pipe that basically aimed the outlet of the t25 to the otherside so it formed sort of an S shape coming out of the t25. i know thats not too good for flow, but do you think it would hurt? thanks.
Ya I would think that should work, its not like the t25 flows alot anyways :p :laugh: Actually making a nice "C" shap shouldn't hurt flow as you wouldn't be forcing the air to make abrupt direction changes. IMO it would be better then the 90 deg silicone elbows that some people use with the IC setups.
