daltah
- 516
- 1
- Sep 27, 2002
phoenix,
Arizona
Can I use rc 440cc injector for a honda as long as they are saturated one? I dont want to have to install a resitor though
BigRand said:I gotta say, this is definatley the wrong forum let alone website to be asking this question, however your injectors should work provided that it is saturated on that honda, without a resistor pack. As for using 440cc it depends on your application and fuel mods to go with it, and what your using to control fuel, and ignition.
I was told 14psi was the max, so if that is close enough you should be good.daltah said:Would 370cc injectors be fine to run 15psi?
