Can i use a SOHC neon bottom end in my 97 2g/nt?
99 gst 420a dsm
509
Jan 22, 2003
Turboville, New York
I was just wondering if i could use a SOHC 2.0L dodge neon bottom end in my 97 eclipse, I spun a bearning and just want to replace the bottom end without buying a crank and bearings
yes, it is the same block, despite weather or not its SOHC. the engine mounts will be in different spots though. because in the neon the exhaust side of the motor is right at the firewall, and on an eclipse the exhaust side is next to the radiator. the motor has basically been reversed.
  • Wanted 6 bolt NT water pipe
    • chrisman287
