Can i use 660's with my safc
JoEgsX90
183
Jun 10, 2006
Yon, New York
Whats going on guys i wanted to get your suggestions. Im looking to get 660's for my car with my safc. Could i control the 660's with my safc or are they to much? Ive read it may be to big but some forums say thats its ok. What should i do.
You will run a lot safer since you are a 2g. The 1g timing map is very aggressive. The fact that you have pull about 30% airflow would cause a 1g to run very high timing off a lower load map. I believe that is the biggest problem with larger than 550s and an SAFC on a DSM.
You should be fine. I plan on tuning a friends car with 650s and an SAFC. (He has a 1g, but I am getting a DSMChip too)
