Can I fix this with a rim spacer?
Eclipse 1998
240
33
Jul 21, 2010
Bloomington, Indiana
So my passenger axle is a autozone one and the axle hits the center cap and protrudes out slightly, can I fix this with a rim spacer?
The first pick is what I'm talking about, the second is for comparison.
From the pics, you can barely tell there's a difference. I'd just run it as is. I've never see anyone run spacers so center caps would fit ROFL
Can you just trim the back of the center cap a bit?
It is noticeable, plus I didn't completely tighten that side bc I didn't want it to tear up the cap. Should I just take a sander to it?
You really didn't answer my question though, can a spacer fix it? Would there be any negative effects?
Well, depends how close it is to fitting?
You may be able to take a Dremel with a small grinding bit and remove some material from the back of the center cap.
If you're really brave, you can even remove a tiny amount of material from the end of the axle shaft itself. Just don't screw up the threads.
You could also run a spacer, but that's a lot of work just to get a center cap to fit. So, to answer your question, yes, a spacer is an option. All the info about spacers here: http://www.dsmtuners.com/threads/help-with-getting-wheel-spacers.491511/#post-153506877
The easiest solution would just be not to run center caps. Clean up the axle nut and shaft with some spray paint...It can actually look pretty good if you put some time into it:
I had them flat black before, which makes the nut and axle much less noticeable to the eye:
You could also run a spacer, but that's a lot of work to get a center cap to fit.
Oh wow I do like that way that looks, although I like the center caps as well
