Can anyone identify this motor or what it cam from
grimdsm
88
May 31, 2009
Adrian, Michigan
Mitsubishi 4G63T4G63T-Yellow
The person i talked to on the phone barley knew english i am trying to figure out if this will drop into my talon, i would have to quess with it having 270 hp that it would be an evo engine?
Well it has 1g motor mounts and all that so you're gonna have to do some swapping of parts to get in to drop right in your 2g Talon.
You'll have to do some minor wiring with the CAS too it looks like.
That engine is kind of too expensive IMO.
i am just curious as to why it has 270 hp and yellow injectors
* Mitsubishi 4G63T
* Mitsubishi JDM Cyclone 4G63 Turbo With Yellow Injectors
* 270HP
* Please Call for Availability
2k seems high i can get Cyclone motors for 800. but i not sure if the for everything or not.
Ya the intake looks like it is for the galant... Yellow tops are evo 3 510cc injectors.. That engine is no different than any 7 bolt out there.. 2 grand for a used engine... ouch..
edit: could be before the 7 bolt switch so it can be a 6 bolt which in no different than any 6 bolt turbo block out there.... My bad..
if its a 6bolt with 510 s and evo3 turbo i believe the motor came from a galant vr4 rs. but could be wrong
2000 sounds pretty expensive to me... theres a jdmengine warehouse in the tristate that you can actually inspect the motors before purchasing them... something off the internet is a hit or miss... but those hp ratings are def off and so is the price... the warehouse i went to had the same engine going for 1200 with all the bolt on parts and warranty.... and if their website is all in english and they can hardly speak it... i'd sense a red flag right away
I would only buy it if it had blue injectors!:p
Definitely looks like a Galant motor. I had no clue that the evo III turbo was in the Galant VR-4. Thats pretty awesome.
2000 does sound like a lot, and 270 hps definitely sounds wrong for an engine that is used and been sitting there in a warehouse. MOST jdm 4g63 engines are under 1500. Aznspice27 brings up a good point about the website being in broken english. I suggest going elsewhere and not paying more than 1500 for it.
