Can anyone help with some advice?
BlazeEclipse99
Jul 3, 2007
Beltsville, Maryland
hello
I live within the tristate area and i am trying to tune my ride. I have a 99 Eclipse GS with no turbo. I was thinking going turbo but i am not sure what could i do first either start up with an cold air intake and step it up to a turbo setting or change the way my engine is formatted? Any information could be helpful and/or any advice could really help me out Thanks
Blaze
I am unsure of what you mean by "change the way the engine is formatted" and "step it up to a turbo setting"
Basic NA bolt-ons such as I/H/E, and UDP, will give you a small, but noticeable, increase in power. If you intend on going turbo in the near future, I would not get the header or intake, as these will be removed from the set-up when you add the turbo.
This link is a good guide, and should have been part of your required reading when joining this board. :) Read that, along with everything in the 420a Section, and you should be well on your way. If you have more specific questions, ask away!
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
