daren_p
DSM Wiseman
- 4,604
- 98
- Nov 22, 2004
Newmarket,
ON, Canada
Well the ride is in storage for the winter so I need to buy some "go fast" parts to bolt on in the spring. Currently I have the evoIII turbo and was running at 18 psi last summer but with the fmic that I installed last fall and arp headstuds I will be turning the boost up to 20 this spring. With the old setup I was seeing ~33 lb/min but with boost turned up to 20 I would like to be closer to the 40 lb/min range. So here's my question, what do you think I should get? (even though I'll end up getting both in the long run
) cams or a new turbo? For cams I would be looking at the FP1's, I know everyone will say just go with the 2's but being Im fwd and I don't think I can pass emissions here with the 2's (and I don't want to swap for the test as they also do street "spot" tests as well). For the turbo I was looking at some kind of 50 trim. Im leaning towards a bb unit. I was origionally thinking SBR gt 11 or 12 but I see the new pte bb units and for the price I might try one of those out. So whats everyones opinion on what upgrade? They will end up basically costing the same since I can sell my evoIII to make up the difference. Which one will give me the bigger gains (@20 psi, street tune, ultra 94 fuel) as this is basically a street car. Thanks
. Too many cars
) with HKS's and her turbo spools up around 4700 with tons of power after. But not very street friendly (as a matter of fact, she barely gets into the turbo. She will shift no higher than 4500 and never goes WOT).
. It looks like alot of guys are leaning towards cams first. That was my origional thought but then with all these bb 50 trims now I started to think new turbo. I do like the quick spool of the evo but I don't think abit more lag would bother me that much. As far as emissions goes being fwd I have to do both an idle & loaded test. I know awd's can get aways with FP2's or HKS 272 no problem, but Im not to sure about my fwd.
Shut the #### up. If you can't give anything useful to the thread, don't even bother posting.
