NA Cams VS Turbo Cams
NA and turbo cams are designed completely different and a larger number spec one way or the other should not be used as a decision to use either in the wrong application.
NA cams have more overlap and usually more aggressive than a turbo profile. Big turbo cams can qualify as NA cams with a little help of adjustable cam gear.
