Cams and Cam Gears
604CruisinCroat
366
4
Feb 17, 2003
Vancouver, BC, Canada
This may be a stupid question, but I need to know nonetheless. Can you change your cams without taking off the timing belt? And I don't think this is possible but, can you change your cams AND cam gears without taking off the timing belt? Thanks.
With most modern cams you dont need adjustable gears anymore.
The FP and COMP cams appear to be dead on the nutz from the shop.
Most people zip tie the gears to the belt and just pull the cams that way.
2-3 hours for a novice and not busting ass either.
