cam
91LASER2N/T
Nov 18, 2003
Hey guys, Ok I was reading about the HKS cams and they said the best way to go was big int and stock exg. Do I have to get there stock exg or can I use the one I have. When I got the car the guy said he put turbo cams in it. Don't know what year thow thanks for any help.
You can keep the exhaust cam you have in there now, and just upgrade the intake. I am looking to do the same set-up. Just not sure if I should get the 264's or the 272's. I am still waiting for a little more feedback on some of the n/t's that have tried the 272's. The guys with the 264's seem to be very positive on their gains.
I'm going to get the 272 for intake and get the mass trans from punishment. anyone know if the springs will be fine or will they need to be upgraded? thanks
Highly recommend upgrading them. With the new larger cam, the engine should be able to rev higher, you will definately want something that can handle the constant rpms along with the higher lift. Upgrade your retainers and guides while your at it as well. :thumb:
