Cam question
dsmusmc
422
Oct 1, 2007
Alliance, Ohio
As of now im running Comp 200's (272's) and plan to stick with them until im ready to do my 6 bolt swap. Once that is in i was wondering how well a 272/280 set up would work or would it just fall on its face and im sure idle will be a mess.:hmm: Iv looked around and havnt really heard of anyone using this setup and maybe thats a hint but ill ask anyways. I am going to be running a Borg Warner 362 with Kiggly mad-bees and hopefully buy then a JMF drag mani. Looking to rev to 8-8.5K or maybe even 9K if turbo has that potental (which im positive it does). I might end up just doing the 280/280 combo and be done with it but didnt really want to kill my spool time another 300-500 RPMs if i didnt have to so thats why i mentioned the 272/280's.:ohdamn: Or would the full 280's setup be the better route? Any thought on this or help will be appreciated.:thumb:
My opinion would be based on what cam brand you are going to buy. Some suck and some don't.
Sticking with Comp or FP4's (i know there the same) if i go with 280/280.
Sticking with Comp or FP4's (i know there the same) if i got with 280/280.
Good choice. I havn't had both in my hands to say they are exactly the same. I have the Comps in my car now and the difference between them and brian crower 280's is night and day. I also had 2 sets of bc280's here and they were not ground on the same lobe center. I would just go the full 280's or have a set ground for you set up.
Well i know they arnt completely the same just FP has the cuts slightly different. My Comp 272's pull like crazy but i know up in that range they are going to run out. I may just go FP4's.
