Buying built tsi
lowdime23
Mar 25, 2010
Russell, Kentucky
Hey im gonna be buying a 95 talon tsi it has 6 bolt swap 1000cc inj. wide band, hks maf,aftermarket fpr, dsmlink, the car is running rough barley idles as soon as u push a lil gas it dies like the inj, are flooding it he says it needs tuned ne info be great buying tomorrow mornin
thats great thanks for the usefull thread any pics
tune?? he has dsmlink.. u can tune it already?? thats odd?? why cant he just fix it.. bet there is something to it.. check if the dsm link works. .
i just needed to know what you all think might be wrong with the motor dieing on acceleration
he just bought the dsm link and put it in he says that he doesnt have the time to miss with it he seems like a stand up dude we seen the o2 sensor wires the fan caught and broke would that be it?? he says it has a rough tune on it
if you don't have that front o2 sensor hooked up.. well, that could be the start to finding the problem considering you need that one...
Well ask him if he has the original injectors and ECU? Put those back on and see if it will run better. You may not be able to push the turbo's limits with stock fuel but it should run better.
yea he has stock inj but not the ecu idles alright acts like it has a cam in it but it dont sounds like that kinda rough but idles but as soon as you add any gas it vuts out now u can miss with it a lil give fuel stop give fuel it will rev up he thinks the inj. are just dumping in it
so the wires are ripped on the o2?? are they stilll there.. take off the fan and if the o2 wires are still there splice them and connect.. and see what happens.. .
and how much??
yea he is gonna wire them up tonight
how much?? if u mean how much i payed for car im trading my 01 eclipse gt loaded for it
oh well thats sound sfair.. both can be found for around the same price.. . just make sure about what ## getting..
yeah i really like the car just hopeing it aint nothin big when i get it can i data log it and send you the results and tell me what ya think
Complete sentances, spell out the words (ne1= anyone), punctuation. I had to read your posts a couple times before I knew what I was reading. Nobody is perfect but please at least make an effort.
I would cover the basics. Do a compression test, check end play on the crank, check shaft play on the turbo. Is it a 5 speed or auto? How many miles are on it? How many miles are on the engine? Was the engine rebuilt prior to swapping it in? Does he have any receipts? Is it front wheel drive or all wheel drive?
Based on the mods you listed, the guy just threw parts at it and didn't follow a good upgrade path. I think you'd be getting a headache.
this is whats done to it Arp headstuds,stainless valves,4inch intake with hks filter,50 trim turbo,3inch turbo back exhaust,hks 40mm external wastegate,hks fmic,hard pipes,greddy bov,1000cc injectors,Dsm link,wideband,ksport coilovers,6 bolt swap with 2g pistons ,1g rods criofrozen,1g cams,air to liquid oil cooler,koyo radiator,hks maf
